1986 Nissan 300ZX battery holds charge intermently
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIGGIRD
Just bouth son his first car and sometimes the battery does not hold charge, new bat and alt checked by professional and says its good. I noticed a fan sound comming from engine when off, can this be draining bat? Have started pulling fuses and relays to isolate sound.
Any suggestions
Oct 15, 2008 at 12:15 PM
TSCHROEDER22
[quote:84aa8e3089="diggird"]Electrical problem
1986 Nissan 300ZX 6 cyl Two Wheel Drive Automatic 147000 miles
Any suggestions[/quote:84aa8e3089]
That fan sound is cooling down your intake manifold and your turbo. Do not pull the fuse for this. If the car has the factory anti-theft system IT is draining your battery. Pull the fuse for that and you will see that problem go away. my 1985 z had that same problem when i bought it,
Nov 7, 2008 at 5:11 AM
