1985 Nissan 300ZX Just blowing hot (engine) air through def
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROMPST
I need to learn as much on why my air conditioning is blowing hot (engine) air up through my defroster vents under the windshield. The blower motor seems to blow, only not through any of the routes the regualr buttons designate, i.e. face, feet, face and feet, etc. Of course, I should add that it started to just blow cold air (through the normal routes) only when you'd let up on the gas. That is to say, it would blow really hot (engine) air through the designated routing when you were on the gas. I have very little money and am afraid of beng ripped off by the many unscrupulous mechanics I've encountered over the years. I have tools and an aptitude for mechanical work. If I know the solution, I can certainly give it a go, and go to a pro if/when I find it too daunting.
Aug 1, 2008 at 11:08 AM
2CARPRO JACK
  • 11,533 POSTS
If the gas pedal changes things you are looking at a vacuum issue. Locate the feed from engine to dash and be sure it is good, no cracks or anything. If ok, you may have a leaking switch in th edash or another vacuum problem there like avent actuator that cant hold.Might need a vacuum pump to help if you find all lines are good
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
this will have all diagnostic and vacuum diagrams to help you figure this out
Aug 2, 2008 at 1:06 AM
