im tryin to find out where my headlight relay/s on my 85 300ZX are located because the label on the relay box cover is missing... thank you
Jul 21, 2009 at 2:17 PM
BLUELIGHTNIN6
✓Experienced Mechanic
Your headlight door relays are located ( one ) inside of each headlight door motor assembly
Jul 21, 2009 at 2:28 PM
85NISSANZCAR
MEMBER
thank you for your response but unfortunately i didnt word my question properly... i rephrased it so i hope i might find out the location of the relay/relays... thank you
Jul 21, 2009 at 4:10 PM
BLUELIGHTNIN6
My last response DID tell you where the headlamp relays are located.....there is one relay per headlamp motor (2), each relay is located inside of the headlamp door motor assembly..
What other relay are you needing to locate?
Jul 22, 2009 at 5:26 AM
