1985 Nissan 300ZX dash panel does not power up
1985 NISSAN 300ZX
183,000 MILES • 6 CYL • 2WD • AUTOMATIC
PREFECT48
the car will start if i rev up the engine sometimes
the dash panel will light up and function properly
I have checked all fuses and the fusible link box
with a check light
do you have any sugestions?
Oct 1, 2010 at 9:11 AM
KHLOW2008
  • 41,814 POSTS
Hi prefect48,
Thank you for the donation.
Check the ignition switch. Symptoms indicates an intermittent power supply failure and the ignition switch is the most likely cause.
Oct 1, 2010 at 10:32 AM
