1979 Nissan 280Z Coolant is dissapearing
1979 NISSAN 280Z
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEVYBOYRADER
My car loses about a quart of coolant every hundred miles. It has problems cold starting and blew a heater line that has since been fixed. Last week it shot coolant out of the resevoir tank but was depleted in the radiator. The radiator does have a dent where the drain plug is but doesn't appear to ever leak. Although I have considered it being the head gasket, There is no oil in the coolant or visa-versa. I doesn't smoke and drives fairly well. It will over heat a little on the highway but not very much. Any help would be very much appreciated. Thank you.
Nov 23, 2009 at 9:09 AM
  • 31,937 POSTS
HI there, start with a cooling system pressure test as this will locate any external coolant leaks, also make sure that the pressure cap is also tested, start here.
mark (mhpautos)
Nov 23, 2009 at 9:15 AM
