fuel in rail and the coil has spark and the car turns over but will not start
Mar 18, 2010 at 10:54 AM
✓Experienced Mechanic
Check the fuel pressure if its within specs and also for injection pulses from the injectors. If okay check the the valve timing and ignition timing
Mar 18, 2010 at 10:57 AM
