1975 Nissan 280Z fuel injectors
1975 NISSAN 280Z
89,000 MILES • 6 CYL • 2WD • MANUAL
MIKE71130
fuel in rail and the coil has spark and the car turns over but will not start
Mar 18, 2010 at 10:54 AM
Check the fuel pressure if its within specs and also for injection pulses from the injectors. If okay check the the valve timing and ignition timing
Mar 18, 2010 at 10:57 AM
