Timing?
SILVIAGUY95
i have a 95 nissan 240sx with the ka24de with around 5000 miles on rebuilt motor which has cp pistons and eagle rods ect., it spun a bearing so i replace the rod bearings and main bearings, then put everything back together set the crank to tdc and set the distributor to spark plug #1 and fired it up then set the idle to around 700rpms. everything sounded good but once i put it in 1st to take off it became very sluggish rpms very slow and it hardly moved once i hit 20mph it stayed the like it hit a governer or something. could the be the timing or am i missing something. thanks in advanced
Oct 4, 2007 at 4:34 PM
MERLIN2021
  • 17,250 POSTS
Only thing I can think of...What size insert? how Tight? If you overtihgtened it maybe....? The Main and rid caps go a certain way, sure about the install?
Oct 4, 2007 at 7:53 PM
2CARPRO JACK
  • 11,533 POSTS
Check the cam timing. Sounds like it is off a tooth, does it free rev slow as well?
Oct 5, 2007 at 1:06 AM
SILVIAGUY95
thank you it was the timing it was at lik e5 degrees atdc so i moved it to 10 degrees btdc which i read was the correct timing
Oct 6, 2007 at 7:30 AM
