1990 Nissan 240SX Steering Shake
HOPE4THAFUTURE
Hi, I have a 1990 Nissan, 240 sx. The only problem i have is in the steering wheel...in between 35 and 45 mph (around there)...my steering shakes weather i am accelerating or decelerating. anything above that is a smooth ride...im hoping its something like a wheel balancing or an alignment but i dont want to waste my money, if anyone has any suggestions i would greatly appreciate it
Mar 11, 2006 at 3:06 AM
FISHERMAN
  • 937 POSTS
you are right could be caused by faulty balanced tires or mis-alignment
start balancing the tires (thats not that expensive)
Mar 11, 2006 at 2:16 PM
Suggested Repair
Start with tire balancing, which is relatively inexpensive. Unbalanced tires or a misalignment can cause steering shake in a narrow speed range.
Conversation Summary
The owner of a 1990 Nissan 240SX reports steering-wheel shake between about 35 and 45 mph while accelerating or decelerating, with a smooth ride at higher speeds. The expert says unbalanced tires or misalignment could be the cause and recommends starting with tire balancing.
