Nissan 240SX Rear Brakes
1924 NISSAN 240SX
ANDKORN
I have a 1990 Nissan 240SX and I'm working on the brakes on it. I replaced all the shoes and rotors, and when I was driving the rear right rotor began emitting white smoke that smelled sort of like burning plastic (not too much smoke). I pulled over and waited for it to stop smoking. After 15 more minutes of driving I checked again and the wheel was hot to the touch, and the other rear wheel was warm. The front wheels where cold. The smoking stopped at this time though.
It is possible that I got some brake fluid on the wheel, but then why where they hot? Also, when I pushed the rear piston back into the caliper (by turning it), is it possible that I didn't push it far enough?
Any ideas?
Thanks!
-Andrew
Jul 15, 2007 at 2:07 PM
2CARPRO JACK
  • 11,533 POSTS
Need to be sure the small locating pin on the back of the pad is sitting in the slot the caliper piston. Might be jammed in there causing the pad to drag
Jul 16, 2007 at 12:56 AM
ANDKORN
Wonderful! After repositioning the rear piston so that the nub on the brake pad fitted into the slot on the piston, the car was much better.
The brakes would still heat up and smell at highway speeds, but after a day it went away.
Thanks for your help!
[quote:4bf6337393="2CarPro Jack"]Need to be sure the small locating pin on the back of the pad is sitting in the slot the caliper piston. Might be jammed in there causing the pad to drag[/quote:4bf6337393]
Jul 22, 2007 at 12:34 PM
