Indicators
RICHARDJR86
I own a nissan 200SX S14a 3 door coupe 2.0l turbo manual gearbox, 90 000 mile reading on clocks
The problem is that the indictors keep blowing fuses and I have had them replaced several times and the same thing keeps happening. It is causing other things to blow such as the hazard lights.
I was wondering if you could be able to help me with this problem as I cant seem to get it fixed?
Nov 24, 2007 at 4:43 AM
  • 31,937 POSTS
Hi there,
You will have to try and isolate the cause of the short. How quickly will the fuse blow? If almost as soon as turned on try this. Unplug all indicator lamps. Fit 5Amp fuse (this will blow quicker than the heaver one) Hook up one light at a time Turn on indicator, it will flash faster, if it won't blow fuse quickly add next globe and try again, if problem is in a globe holder or loom plug you should be able to isolate the problem area. Hope this helps.
Mark (mhpautos)
Nov 24, 2007 at 8:06 AM
