I have a leak in the exhaust, but don't know where
NISSAN 240SX
FABIAN
I have a 240sx 1990. I have been having trouble with the exhaust manifold. Is there anything that I could spray in the exhaust, around the gaskets and in the join with the rest of the exhaust to see if there is any leak? I hear the pssss and after a bit I see a little bit of smoke coming up, but can't see from where. I don't know if there is any spray I could use safely to detect where the smoke is coming from. Thanks.
Apr 14, 2006 at 4:41 PM
CBAILEYII
  • 26 POSTS
Is there a general area from where you are hearing the leak? I would say that if you are hearing it in the bay area, you can try sprating some carb cleaner on the manifold gasket area. If it evens out, you know the gasket is bad. However, there really isn't anything to recommend putting into the system to help show where the leak is, since it is the exhaust and thus post combustion.
Anyone else know of some type of UV or blacklight solution like they would use in an AC leak test???
Apr 15, 2006 at 3:45 AM
FABIAN
I wonder if im not gonna cause a fire with the carb cleaner. I hear a pssss but can't see if its the manifold, after a couple of minutes running I see a bit of smoke come up, I replace the o-rings between manifold and pipe but that didn't solve the problem. Is it dangerous to run the car with a leak like that?
Apr 15, 2006 at 2:01 PM
CBAILEYII
  • 26 POSTS
The biggest issue syou need to isolate is where it is at. I can help but wonder whethe it is a vacuum leak you are hearing vice an exhaust leak. The "puff of smoke" issue brings up a lot more questions that I may not have the answers for so I would leave that up to someone more knowledgeable.
I have done teh carb cleaner test a number of times, and I still have all of my hair. The issue is with flammable fluids is commonly exposures to open flames or sparks. Kinda like putting lighter fluid on burning embers, doesn't really ignite until you blow on the embers and get a spark.
Apr 16, 2006 at 9:26 AM
REDNEC414
  • 7 POSTS
[quote:256f3d8e85="cbaileyii"]Is there a general area from where you are hearing the leak? I would say that if you are hearing it in the bay area, you can try sprating some carb cleaner on the manifold gasket area. If it evens out, you know the gasket is bad. However, there really isn't anything to recommend putting into the system to help show where the leak is, since it is the exhaust and thus post combustion.
Anyone else know of some type of UV or blacklight solution like they would use in an AC leak test???[/quote:256f3d8e85]
acually a spray bottle and soap will work
Jun 20, 2006 at 4:51 PM
SNIKREPN
  • 17 POSTS
Exhausts can be repaired, but I would not advice you to go that direction. Repairs are usually expensive since you will repair it today and tomorrow it breaks down again. What will you resort to if not repair it again..do some replacements and consider quality exhaust systems.
Mar 8, 2013 at 4:27 AM
