1994 Nissan 240SX Spark Plug Choice
ALAN_DUDE
My son just bought a '94 Nissan 240 sx 2.4L, 150k miles. I told him to service the car and start from scratch. I recommend with that many miles to use hotter plugs. However I'm not sure if hotter plugs are longer and might cause any kind of internal clearance problems with this car? What about Platinum plugs, are they good for high mileage cars?
Oct 2, 2007 at 7:28 PM
FISHERMAN
  • 937 POSTS
[quote:28428d7a76="Alan_dude"]My son just bought a '94 Nissan 240 sx 2.4L, 150k miles. I told him to service the car and start from scratch. I recommend with that many miles to use hotter plugs. However I'm not sure if hotter plugs are longer and might cause any kind of internal clearance problems with this car? What about Platinum plugs, are they good for high mileage cars?[/quote:28428d7a76]
Hello!
Well i would recommend to use original "plugs"
a fresh set of NGK`s " "V" power are really good and Inexpensive!
Platinum are good also but expensive and you didn`t feel the difference just last a little bit longer (never use Bosh those plugs are really bad)
Good Luck !
Oct 11, 2007 at 7:55 AM
Suggested Repair
Install a fresh set of original-spec NGK V-Power spark plugs. Platinum plugs last a little longer but cost more and offer little noticeable difference. Avoid Bosch plugs, and do not switch to a hotter plug heat range.
Conversation Summary
The owner of a 1994 Nissan 240SX 2.4L with 150,000 miles asked whether hotter spark plugs are longer and could cause internal clearance problems, and whether platinum plugs are suitable for a high-mileage car. The expert recommended original-spec NGK V-Power plugs, said platinum plugs last slightly longer but cost more with little difference, and advised against Bosch plugs.
