Engines rpm too high, high acceleration
HELPNEEDED1
I have
Nissan Sunny
2000 model
1.6L
100,000 Kms
Automatic transmission
Normally, the RPM in neutral is 900-1000rpm. All of a sudden, I started facing the following problems:
1. At neutral, the engine rpm is now 1200. It keeps fluctuating and there are some air sounds.
2. When I start driving, within a few seconds, the transmission shifts to second gear, which is abnormal.
3. The acceleration is very fast.
4. At low speeds the engine makes a lot of sound.
5. When braking to a complete stop, the rpm suddenly increases when the transmission downshifts to first gear. As a result, I have to apply the brakes really hard as the car refuses to stop.
6. Due to the increased rpm, my tranquil Sunny sounds like a race car.
Please help me..
Apr 24, 2007 at 4:44 PM
  • 75,988 POSTS
Check the throttle cable adjustment, Throttle position sensor, throttle plate for binding/sticking.
Could also be a vacuum leak
Apr 25, 2007 at 11:17 AM
HELPNEEDED1
Thanx a lot, I took it to the mechanic, and he found a similar problem. He says the throttle body (whatever that is!) is damaged.
I will try and replace it and see if it helps!
Thanx
Apr 25, 2007 at 3:50 PM
