1996 Nissan 240SX Thermostat issues
180,000 MILES • 4 CYL • 2WD • MANUAL
BRIANS14
Hello, Recently the temp gauge in my car started rising and cooling off very frequently (seemed to be everytime i hit the throttle and let off.) I assumed it was the thermostat so i changed it. After changing it i turned on the car with the radiator cap off to bleed the system. I saw no coolant flow through the radiator and soon after my car started to overheat. I determined the thermostat was stuck closed and defective so i returned it and bought a new thermostat made by a different manufacturer. I installed the new thermostat once again, making sure the jiggle valve was upwards and the spring going in towards the engine. Same problem. After some thinking i thought the water pump could possible be failing so i replaced it with a remanufacured one. This again did not fix the problem. I changed the thermostat for the third time and now my car would not reach the average operating temp as if i was not running with a thermostat at all! Im lost. Any help would be greatly appreciated. Thanks.
Brian Cookson
Jan 25, 2010 at 2:02 PM
  • 75,988 POSTS
Check and test the coolant temperature sensor might be out of calibration or the guage itself also try bleeding it
Are you actually overheating?
Jan 25, 2010 at 4:20 PM
BRIANS14
Not sure. The temp gauge has not worked since i bought the car but i have a aftermarket one installed to the water temp. I no they are not very accurate but i have not gotten around to fixing the stock gauge. Whats the proper way to bleed the system? Ive tried leaving the rad. cap off while idling the car and i have tried pulling the screw (i assumed the bleeder screw) at the housing for the lower radiator hose. Both times i had no coolant flow as if the thermostat was stuck closed. I will try testing the temp sensor. Thanks for the help!
Jan 26, 2010 at 1:10 PM
