1996 Nissan 240SX no spark to distributor
132,000 MILES • 4 CYL • 2WD • MANUAL
96SILVIA
  • 11 POSTS
my engine was rebuilt. I painted the engine bay while waiting for the engine to be completed.
I put the engine back in and tried to start the car. Now I get no spark to the spark plugs. the starter works but the engine wont start. I ground out a spark plug and didn't see any spark when I tried to start the car.
the reason I bring up the painging of the bay is I was wondering if there was a ground issue some place
also could the Crank Position sensor stop spark?
May 26, 2010 at 2:54 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
May 26, 2010 at 8:06 AM
96SILVIA
  • 11 POSTS
I tried replacing the distributor with one that was off a car that was running. That didn't work either. I checked the harness. its ok too
May 27, 2010 at 2:08 AM
