1996 Nissan 240SX My car is turning over but it won't start
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEVIEB 26
The other day I cranked up my car,drove for lunch to burger king.Shut the car off then came back out cranked the then nothing.So I immediately thought my fuel pump failed.So I went and pulled the fuel line located on the fuel filter bumped the car to see if there was any fuel and nothing.So I checked to see if I had any spark,and sure enough there was no spark.So as of right now I currently have no fuel and no spark to my engine.So I was wondering if anyone could help me with this mystery?
Jan 9, 2008 at 6:59 AM
  • 75,988 POSTS
Do you hear the fuel pump when you turn key to run position? If not
Check these items-All the fusible links, the ECCS relay at behind the right kick panel, and both ignition relay 1/2 at fuse block.
Also check all the fuses then comeback
Jan 9, 2008 at 7:13 AM
