1993 Nissan 240SX Trunk won't latch closed
1993 NISSAN 240SX
ADR0098
Interior problem
1993 Nissan 240SX Manual
So the other day my trunk wouldn't close. I looked at the latch and I think there is a spring missing.
I rigged some rope and tied a rubber band to the little knob that hangs down that is supposed to get pushed over to the right to latch the trunk shut then I closed it and pulled the rope to pull the latch shut manually. IT WORKED!
but. nevertheless. I would like to have a regularly functioning trunk.
Can you tell me 1. if it for sure is a spring that I need. 2. will any spring do or is there a specific one for this. and 3. Where can I get one?
Your help is appreciated!
May 13, 2009 at 5:54 AM
2CARPRO JACK
  • 11,533 POSTS
If parts have fallen out of the latch assembly, a new one is in order.If you can find the old spring, then I suppose you could match it up and use any one, but a new latch would probably be a lot less trial and error and much easier in the long run
May 15, 2009 at 12:48 AM
