1994 Nissan 240SX frame
1994 NISSAN 240SX
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
CBRAND21
im looking at buying a 94 nissan 240sx for $500 the owner side swiped a pole on the driverside rear and i wont to know how to tell if the frame is bent or tweeked or if its worth buying if it is bent?
Aug 17, 2009 at 9:00 AM
  • 31,937 POSTS
You wont know the extent of the damage until you have a chassis drop tested done, this will check the full frame alignment, you wont tell by eye if it is going to be a problem, i good panal beater will be best placed to advise you on inspectin this first hand, start here.
mark (mhpautos)
Aug 17, 2009 at 10:53 AM
