1993 Nissan 240SX overheating
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOUGLASKONERMAN
Car gets up to normal temp then creeps its way up to hot. replaced thermostat and still same problem. not getting any heat either on inside of car. water pump isn't leaking and looks like its operating properly. Car not leaking anywhere else at least to the point where it would cause my car to overheat.
Feb 2, 2009 at 6:42 AM
  • 75,988 POSTS
No heat check the heater core if its clogged-up
Overheating-Get it block and pressure tested
Feb 2, 2009 at 6:53 AM
