1993 nissan 240sx 140000, ka24
1993 NISSAN 240SX
FOOFANOOGAN54
The number three cylinder isn't working. I already checked the spark plugs and wires and they work. The other cylinders are working. My engine is shaking pretty bad. I think I might have a dead whole. Or I need a new valve. Any ideas?????????
Mar 20, 2007 at 5:48 PM
[quote:f68e9b1977="Foofanoogan54"]The number three cylinder isn't working. I already checked the spark plugs and wires and they work. The other cylinders are working. My engine is shaking pretty bad. I think I might have a dead whole. Or I need a new valve. Any ideas?????????[/quote:f68e9b1977]
How did you check the plug wires? Eye balling it is not reliable-use an ohmmeter to check its resistances.
Have you check for a cyclinder leakage on the no.3
Sure its not an engine mount
Mar 20, 2007 at 6:42 PM
FOOFANOOGAN54
I checked the wires and the resistance is fine. Since my third isnt working, would that make my engine shake bad. Should it be running fine. How would I check for leakage?
Mar 21, 2007 at 4:23 AM
You need to check the compression on it wet and dry test.
Not satisfied-if you got a compressor pressurize the cylinder with correct adapter and see where its leaking on the no.3 cylinder
Pointers: 1. Coming out of the dipstick points to rings
2. Out of the throttle body- intake valve
3. Out of the exhaust -exhaust valve
HTH Good Luck
Mar 21, 2007 at 1:54 PM
