1992 Nissan 240SX wont shift right
1992 NISSAN 240SX
FARGUS
Transmission problem
1992 Nissan 240SX 4 cyl Two Wheel Drive Automatic
we are not shure of the problem just put in a known good transmission and still have same problem we had bfor witch is to get car to shift gears u have to hit high revs and when u let off gas rpms drop to 1,000 like its in nutral
May 18, 2009 at 8:26 AM
GREY240SX
  • 7 POSTS
You need to check your rear end. It could be damaged on the inside. If that is not it have the ecu checked.
Sep 12, 2009 at 3:37 PM
