1992 Nissan 240SX Knocking and grinding noise
198,000 MILES • 4 CYL • 2WD • MANUAL
KOOMLEE08
  • 30 POSTS
When I turn on my car while holding the clutch I can feel it grind a little. When it idles I hear like a knocking noise from my tranny. The noise is from the middle of my car not my engine for sure. When it idles it knocks, but when I push the clutch down it goes away. I think it's not my throwout bearing because you should already hear it grinding a little alredy. Plus, it should make noises when I push the clutch down. Right? Well, when I drive and shift gears it feels like a grind everytime I let go of the clutch and push it. I dont hear the knocking noise no more though when I drive. You can just feel the clutch pedal grinding everytime you shift. It's weird. I think the knocking could be from my clutch fork knocking agianst the housing. But when I drive it grinds. Help me. Thanks.
Dec 17, 2008 at 10:34 AM
KOOMLEE08
  • 30 POSTS
I just replaced my cluthc like 4,000 miles ago. I used the same throwout though because the new one I got with my clutch kit was different. I jus used the old one because it was still good. Don't know now.
Dec 17, 2008 at 10:37 AM
