1992 Nissan 240SX
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
HOLLIE346
I had my car checked, and I have blown a head gasket..it still drives if I'm careful...is their a liquid seal I can purchase to help engine performance, until I can get gasket fixed? or anything else I can do?
Sep 3, 2009 at 4:58 AM
BOB123456
  • 13 POSTS
even if there was a substitution to fix it, mixing it in the oil or taking off the the head to apply would be troublesome. If you know anyone on the forum or a budy to tell you different by all means take their advice
Nov 27, 2009 at 12:02 PM
BOB123456
  • 13 POSTS
also, obviously, if you take the head off to apply you Though you can drive it until the car has warmed up, because once the thermostat opens you risk antifreeze mixing with the oil and burning.Giving off white smoke and you have to do a massive clean when you do change the gasket. If you know anyone with general knowledge on these subjects do it and try to remeber where all bolts and vaccum lines go
Nov 27, 2009 at 12:06 PM
