1991 Nissan 240SX Running rough
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
UCONN7KMW
Car starts ok, but when driving it run ok for awhile then gets rough. Other then plugs and wires or bad gas, what should I check?
Also, when driving down the road, sometimes the RPM's go up with out touching the gas pedal.
Feb 18, 2009 at 5:12 AM
  • 75,988 POSTS
Inspect/clean/test the IACV-AAC valve and the throttle position sensor
Feb 18, 2009 at 6:44 AM
