1991 Nissan 240SX overheating
1991 NISSAN 240SX
NETOROCKERO
Engine Cooling problem
1991 Nissan 240SX Two Wheel Drive Manual 172200 miles
my nissan 240sx 1991, goes half way on the temperture gage , some time a little more high , the water on the reserve bottlle is boiling at times , the waterpump is farelly new and there is no thermostat , i thought that was the problem , is it normal that the water be boiling ?
Jun 19, 2008 at 11:09 AM
Bleed the cooling system out and see what happens-and put on a thermostat it plays a part of the engine management control system.
The radiator electric fan is it coming on?
Jun 19, 2008 at 11:15 AM
NETOROCKERO
yes the elecrical fan works perfect
Jun 19, 2008 at 11:21 AM
Bleeding the system don't work-get it block and pressure tested.
Jun 19, 2008 at 11:24 AM
NETOROCKERO
thanks , i will bleed it, check the pressure and see what happens
Jun 22, 2008 at 11:26 AM
