I have put a new clutch in my car after replacing the one that went out after a good amount of time for a clutch. once i put the new clutch in it started slipping the first time I drove it. once i replaced that one i did see what looked to be like a finger print on the clutch. which i thought was the problem. so I was extra careful this time when putting the newest clutch in... but it also started to slip right after i put it in.. It slips the worst after the car has warmed up. Could I have some kind of leak or something getting onto the clutch causing it to slip? i would hate to replace it again without knowing what the problem thats causing it is. so if you could help me out i would greatly appreciate it.. thank youfor your time.
Oct 25, 2010 at 12:57 PM
