1990 Nissan 240SX won't star when worm
1990 NISSAN 240SX
SILVIAS13
Engine Mechanical problem
1990 Nissan 240SX 4 cyl Two Wheel Drive Manual ??? miles
ok i have a nissan 240sx, and i have this problem that in the morning when i start the car it don't show no problems, but later on the same day when i start the car again it takes time to turn feels like there is no gas going to the injectors, becasue the car will start if i push the gas all the way in and idle is slow. what it my be the problem?
Aug 14, 2008 at 10:26 PM
A240SX
  • 27 POSTS
When you turn the key on (without cranking the car) does the fuel pump turn on? You should hear it for about 3 seconds. Also check to make sure you are getting fuel, remove the fuel filter and see if it is dirty. if you are getting fuel to the fuel filter and the fuel that comes out is not dirty then it could be injectors. or you may be getting fuel but no spark.
- Let us know what happens
Thomas
Aug 15, 2008 at 7:36 AM
NIKKO421
you might have leaking fuel injectors and if that not it check your mass air flow meter
Aug 30, 2008 at 3:12 PM
