1989 Nissan 240SX temp sensor
78,000 MILES • 4 CYL • 2WD • MANUAL
JAXSTER1
the temp sensor works every once and a while do i need a new one or is there a way to fix it?
Jul 27, 2008 at 7:03 PM
A240SX
  • 27 POSTS
It would be a bad ground. Check to make sure that the temperature sending unit (located near the thermostat) is plug correctly (like its not falling off or broken) Hope this helps
Jul 28, 2008 at 1:58 AM
