Engine shuts off when parked
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
VLADY82
The rpm's on the car are low like it feels that it wants to shut off. The engine is vibrant more than a usual engine and the car will turn off while it is parked but it will turn on without issue.
May 4, 2019 at 6:04 AM
  • 110,248 POSTS
Welcome to 2CarPros.
A low idle speed which can cause an engine to stall can be caused by a few things. First, is the check engine light on? If it is, you need to scan the computer for diagnostic trouble codes. Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but most parts stores will check it for you or rent / lend you a scanner.
Now, an engine vacuum leak can also cause this to happen. Here is a link that shows how to check for a leak:
Here is a link that discusses common causes and how to diagnose an engine stall at idle. Take a look through it and let me know if it helps.
https://www.2carpros.com/articles/stall-at-idle
May 4, 2019 at 2:51 PM
