1997 Nissan 200SX 4 cyl Front Wheel Drive Automatic
How do you change a serpintine belt
Apr 10, 2009 at 5:00 AM
ZACKMAN
✓Experienced Mechanic
You have to adjusters. One under the alternator, the other under the P/S pump. Loosen the lock and then the adjuster bolt, move the alternator or P/S pump to loosen the belt. Remove and replace the belts. Advise to replace both belts at the same time. Install is reversed.
