1984 Nissan 200SX Ticking and Stalling
1984 NISSAN 200SX
124,000 MILES • 4 CYL • FWD • AUTOMATIC
TOPE2121
My car has started to stall at random moments, either idling or driving. The engine cranks over but won't start. Usually all it takes is 30 sec of rest till it starts again.
What I have noticed though is when it won't start, the key is in the "on" position and a loud ticking is coming from the cylinder head. The ticking continues at half second intravels until it stops, at which point it sounds like some pressure or liquid is released for 2 secs. As soon as the ticking stops, the car starts right up. Please help
Mar 31, 2009 at 11:49 AM
JAMES W.
  • 2,394 POSTS
It sounds like your fuel pressure regulator is sticking. If this happens it will hold the fuel back from the injectors creating a "no start" until the pressure releases and then everything is normal. I'm assuming this only happens once in a while. A fuel pressure test will confirm this. Let me know what you find.
Mar 31, 2009 at 2:58 PM
