1992 Nissan 180SX lightweight flywheel
SAGABOY
Engine Performance problem
1992 Nissan 180SX 4 cyl Two Wheel Drive Manual
how would a nissan sr20det engine perform with a lightweight flywheel would be able to get low end power and topend power?
Aug 20, 2009 at 7:02 AM
  • 31,937 POSTS
Hi there,
With fitting a light weight fly wheel there car some gives and takes, you can get a small increase in top end performance as the engine is not working as hard to move the extra mass of the heavy fly wheel, engine response will pick up for the same reason, but you can loose some idle quality as the flywheel is a mas balance that help keep momentum going smoothly at low engine speeds, i would talk to someone who has fitted on to see how they feel about the conversion personally.
mark (mhpautos)
Aug 20, 2009 at 11:39 AM
