How to remove the newer style PCV valve?
175,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
HAMMY0515
How do I remove the PCV valve without breaking something? It has plastic tabs that go over the valve.
Aug 29, 2023 at 7:12 AM
  • 110,251 POSTS
The PCV valve should screw in and out of the valve cover. See pics below. Are you seeing something different?
If you are, could you take a pic and upload it for me to see?
Aug 29, 2023 at 12:33 PM
HAMMY0515
This is what it looks like it doesn’t screw in it has really thick tabs that go over it looks like it will break easily.
Aug 29, 2023 at 1:03 PM
  • 110,251 POSTS
Is it possible to get a pic of the tabs? The manual is showing the screw in one I attached.
Aug 29, 2023 at 1:08 PM
