Does my transmission need replacing
175,000 MILES • AUTOMATIC
ANGB23
My car's transmission started slipping when I would accelerate, eventually it would not go at all. i checked and added over a gallon of transmission fluid. All that has come back is reverse. does this sound like the whole transmission is shot? or where do i go from here?
Apr 24, 2018 at 6:09 PM
HARRY P
  • 2,292 POSTS
Yeah, I would say that the transmission is shot. If you had checked it as soon as it started slipping, it might, repeat might, have been okay. Continued driving while it was so low on fluid caused the transmission to overheat and burn the clutches up. Sorry for the bad news.
Apr 24, 2018 at 8:26 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You want to find that leak also, because if it is external to the transmission or even a broken oil cooler inside the radiator, then after you install a new transmission it will not last very long with a leak.
Apr 25, 2018 at 12:55 AM
