New starter,spins,will not engage,works at parts shop
2005 CHRYSLER PT CRUISER
153,000 MILES • 2.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
SCHOETTLINJ
When changing starter cable grounded when attaching positive cable. Battery cable connected correctly on starter, the other cable grounded.
Dec 4, 2019 at 1:42 AM
AL514
  • 5,663 POSTS
Hello,did you accidentally attach the ground wire to the positive on the starter?
Dec 4, 2019 at 1:53 AM
SCHOETTLINJ
No,no starter has 2 wires attached to it. One from battery has plastic housing, it supposed to go on first. The other wire powers all else,this one was touching the starter. When I touched the positive cable to battery it grounded.
Dec 4, 2019 at 2:24 AM
AL514
  • 5,663 POSTS
Well if any power wires touched any metal you blew a fuse, so go through all of the fuses under the dash board and in the engine compartment. Use a test light and check both sides of every fuse and make sure none of them popped.
Dec 4, 2019 at 2:59 AM
SCHOETTLINJ
Diagnosed code is p0700. Figure I burned ground wire. I don't know where to check.
Dec 4, 2019 at 8:54 PM
AL514
  • 5,663 POSTS
The p0700 code is a transmission malfunction code, so I would start by checking every fuse under the dash and in the engine compartment. You can do this with a test light connected to battery negative and touch both sides of each fuse with the key in the on position. Most likely it burned a max fuse. Check them all very thoroughly. I'm assuming this code just appeared when that wire grounded out. Let me know what you find.
Dec 7, 2019 at 1:10 AM
