New radiator installation
120 MILES • V8 • 2WD • AUTOMATIC
LONNY HADLEY
I bought a replacement radiator and the transmission lines seem to be a different thread, they look the same size.
But the threads look more course and can’t get them to start. Any suggestions?
Nov 3, 2019 at 8:12 AM
Good evening,
You may need to adapters for the lines. If you have a standard radiator and you had a heavy-duty radiator, the lines are different sizes.
Is the replacement identical to the old one?
Nov 3, 2019 at 8:49 AM
LONNY HADLEY
No, the old one was original and the new one is aluminum.
Nov 4, 2019 at 12:37 AM
That is the difference. You need to get adapters for the lines or you will need to cut the ends off the lines and get fittings that go into the radiator and use compression fittings to tie them together.
Nov 4, 2019 at 12:49 AM
LONNY HADLEY
Do you happen to know where I can purchase the adapters?
Nov 5, 2019 at 4:34 AM
Parts stores, Fastenal. All these places will have good brass adapter selections.
Nov 5, 2019 at 5:04 AM
