New passenger side blend door actuator doesn't line up
2008 MERCURY SABLE
235,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
JRONCO219
New blend door actuator works, but the peg seems to be 180 rotated from where it needs to be. Pulled the climate control fuse to re-calibrate the actuators, but it is still out of alignment.
Mar 4, 2014 at 10:49 PM
The blend door does not require calibration on this vehicle, so I am attaching the process on how to replace the blend door just to make sure we are not missing something.
I am attaching the info from the manual for this as well.
However, what I would suggest we do is remove the actuator but leave it plugged in and turn the A/C on full hot or cold and then manually move the door to that position. Then you can install the actuator as it will move to this same position when it is removed.
Let's run through this info and we can go from there. Thanks
Mar 13, 2022 at 11:12 AM
