New motor no power
108 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SOMEGUY4469
Hi, okay, I had my truck parked for awhile one day wouldn't start took it to a shop he said it's wired completely wrong and rewired it got it going. It started to bog really bad like it was plugged somehow. I had the motor replaced. Got burned on that and ended up having it replaced under warranty. Drove it and it's the exact same thing that was happening before it's like it's plugged. any ideas?
Jul 26, 2019 at 3:33 AM
  • 110,248 POSTS
Welcome to 2CarPros.
When you have a power loss like this, the most common cause is a plugged catalytic converter. If the engine can not properly exhaust, it builds back pressure and you have a big power loss. Interestingly, you described it as feeling like it is plugged.
Here are a few links I want you to look through. The first describes symptoms associated with a plugged converter. The second and third describe hot to test a converter and replace one. Check that first and let me know what you find.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/catalytic-converter-replacement
____________________________
If you are able to, remove the pre catalytic converter sensor and see if it makes a difference. Because of the size of the sensor, it won't feel perfect, but you should notice a difference.
Jul 26, 2019 at 1:21 PM
