After replacing the brake lines, brake booster, and master cylinder, the brakes do work and the pedal goes to the floor?
199,000 MILES • 4 CYL • AUTOMATIC
PATTERSONWINDY
I have replaced all brake lines. I have replaced brake booster and master cylinder and brake pedal still sinks to floor with no brakes. Help
Feb 19, 2023 at 10:24 PM
  • 55,604 POSTS
Did you bench bleed the brake master before installing it? If not, this needs to be done. Please check out the video below.
https://youtu.be/WDxvEQrMkBg
This guide can help as well:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
If the brake master was bled, then you have air stuck in the ABS unit so the valves inside the unit will need to be held open while you bleed the system. Please check out this video to show you how:
https://youtu.be/nQRnKyVyMuQ
Please let me know how it goes.
Feb 20, 2023 at 4:24 AM
