New LED lights affect my turn signals flash
266,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ROYCAR71
  • 359 POSTS
After installing LED headlights my turn signals flash erratically. What can I do?
Oct 27, 2017 at 6:18 PM
STEVE W.
  • 15,423 POSTS
Common issue. The LED's mess up the current draw through the system. The only good solution is to switch back. One of the problems with having computer control of everything they are set up for the OEM parts only.
Oct 27, 2017 at 6:55 PM
ROYCAR71
  • 359 POSTS
Will load resister on wire of headlights matter much?
Oct 28, 2017 at 1:25 AM
STEVE W.
  • 15,423 POSTS
It might but if you have to add resistance it may cause other issues.
Oct 28, 2017 at 2:38 AM
ROYCAR71
  • 359 POSTS
I put back stock headlights. I replaced turn signal multi switch on steering wheel. I still get intermittent signal on both sides.
Nov 3, 2017 at 7:53 PM
