After installing LED headlights my turn signals flash erratically. What can I do?
Oct 27, 2017 at 6:18 PM
STEVE W.
✓Experienced Mechanic
Common issue. The LED's mess up the current draw through the system. The only good solution is to switch back. One of the problems with having computer control of everything they are set up for the OEM parts only.
Oct 27, 2017 at 6:55 PM
ROYCAR71
MEMBER
Will load resister on wire of headlights matter much?
Oct 28, 2017 at 1:25 AM
STEVE W.
It might but if you have to add resistance it may cause other issues.
Oct 28, 2017 at 2:38 AM
ROYCAR71
MEMBER
I put back stock headlights. I replaced turn signal multi switch on steering wheel. I still get intermittent signal on both sides.
