New fuel pump, no fuel?
174,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
RETIRED62
The car has quit no fuel pressure at fuel rail replaced the fuel pump turned key on and you can hear the pump run but no fuel thought I had gotten a bad pump replaced it again no fuel but you can hear it run removed it and replaced it again still same problem I have tested the FPDM and it all tested ok I still have no fuel coming out of the fuel pump module the only time I see any fuel is with the fpm loose in the tank fuel moves thru the small clear li in the fuel pump module.
Jun 13, 2023 at 6:56 AM
  • 110,248 POSTS
Did you replace only the pump motor or the entire module? If it was only the fuel pump motor, chances are something is not attached or connected correctly.
Jun 13, 2023 at 1:55 PM
