Recently had fuel pump changed. Check engine light still on. Check gas cap light came on while starting home. It went out a couple days later, but is now back on. Sometimes car idles fine, but more often not. Sometimes hard to re-start. Sometimes shuts off at stop. Bad pump maybe? Even though it is new, the mechanic sent the first one back, not enough fuel pressure. I don't know the odds of getting two in a row bad. Bad seal at fuel pump? The car is tending to run better with full gas tank, gets worse as gas is used up and it gets under 1/2 tank.
Jul 14, 2019 at 11:58 AM
