New clutch chatter
150,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
SUPERSAAB
  • 19 POSTS
I just installed a new stage 2 clutch kit about 700 miles ago. I drive without hitting boost for about 500 miles for brake in. I got on it hard the other day and when I got to about 10 psi boost I heard a loud banging sound. Could hear it over my load music. When I got home I realized my clutch was making a lot of noise. It gets better or worse depending on pedal position. I can still shift gears if I don't push the pedal all the way. If I push it all the way down it grinds and can't shift. The chatter is there all the time but like I said it changes depending on pedal position. What could it be? Damper springs? Or something else entirely? Please help.
Aug 22, 2020 at 11:35 PM
Good morning,
Sounds like the pressure plate or the throw-out bearing.
You will need to tear it down and inspect the clutch itself.
https://www.2carpros.com/articles/how-to-replace-a-clutch
Can you upload a video of the noise so I can hear it?
Aug 22, 2020 at 11:46 PM
SUPERSAAB
  • 19 POSTS
Here is a video. Hopefully you can hear it.
Aug 23, 2020 at 4:23 AM
Okay, thanks.
Sounds like the throw-out bearing.
YouTube video for replacement.
https://www.youtube.com/watch?v=6N6b5F2ChyE&t=1819s
Aug 23, 2020 at 6:51 AM
SUPERSAAB
  • 19 POSTS
Okay, thanks. I have another kit on the way. Going to tear it back down when it gets here. Hopefully everything in this kit is good. Thanks
Aug 23, 2020 at 7:00 AM
You are welcome.
Make sure you either have the flywheel cut or replace it.
Aug 23, 2020 at 7:19 AM
SUPERSAAB
  • 19 POSTS
I replaced it with that last kit. if it got nics I'll figure something out.
Aug 24, 2020 at 4:32 AM
Sounds good. I just do not want it to chatter when you let the clutch out.
Aug 24, 2020 at 6:22 AM
SUPERSAAB
  • 19 POSTS
I'm really just hoping it not and input shaft bearing.. at least you gave me a little piece of mind...
Aug 24, 2020 at 6:36 AM
If it was that bearing you would have a roaring noise from the bearing.
Aug 24, 2020 at 6:54 AM
SUPERSAAB
  • 19 POSTS
I didn't have any of that. it just popped and now the noise.
Aug 24, 2020 at 9:25 AM
Okay, then most likely there is no input bearing damage at all.
Aug 24, 2020 at 9:33 AM
SUPERSAAB
  • 19 POSTS
Alright, thanks for the help.
Aug 24, 2020 at 9:44 AM
You are welcome.
Always glad to help.
Aug 24, 2020 at 9:54 AM
