After replacing the brakes do I turn the car on while depressing the brake to take the tolerances?
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
KATOTONIC
After completing installation of my new brake pads and rotors, should I turn the car on while depressing the brake to take the tolerances? Or does the car remain off?
Apr 24, 2024 at 10:51 AM
  • 110,248 POSTS
I always do it with the engine off. Also, only pump the pedal approximately halfway to the floor. Avoid allowing it to reach the floor. It could cause internal damage to the master cylinder.
Gently pump it as mentioned until the brake pedal feels firm again.
Let me know if this helps.
joe
Apr 24, 2024 at 12:45 PM
CARADIODOC
  • 34,414 POSTS
Doesn't matter. Running the engine just gives you power assist which makes the pedal easier to push.
I'm glad you asked though because there's one huge potential pitfall to avoid. During normal driving, you never push the brake pedal more than roughly halfway to the floor. As such, the two pistons in the master cylinder never travel through the lower halves of their bores. After about a year, crud and corrosion begins to build up in those unused areas. Later, when you push the brake pedal to the floor, the rubber lip seals get run over that crud and can rip them. That causes a slowly sinking brake pedal, and it commonly takes about three days for that to show up. You can usually buy master cylinder rebuild kits, but it's almost always less expensive to buy a professionally rebuilt master cylinder with a warranty.
This damage can occur when pumping the brake pedal to run the caliper pistons out to adjust them, like you're asking about, when a brake hose pops, and even the instructions in some service manuals tell you to push the pedal to the floor when bleeding the hydraulic system with a helper. (Doing so can cause a whole different hard-to-diagnose problem on GM vehicles). The bottom line is never push the pedal over halfway to the floor. Those half strokes are more than enough to run the caliper pistons out.
As a point of interest, that crud can build up behind the caliper pistons too and cause trouble. I use a flat-blade screwdriver to pry the pistons into the housings first, before I remove the calipers from their mounts. If they go in smoothly, they aren't going to cause a problem. If you have to remove the caliper, then resort to using a c-clamp, which I never approve of, you're driving the piston over that crud or you're driving a rust ring on the piston under the rubber square-cut seal. Either one will cause brake dragging and overheating.
Good practice is to run a flat file over the piston where it contacts the backing plate of the inner pad, and over the fingers of the caliper where they contact the outer pad. The goal is not to shine them up. It's just to remove any high spots of rust or dirt that will interfere with the pads sitting squarely. That dirt can help a vibration to occur that we hear as a squeal. Use a little high-temperature brake grease on those pad backing plate contact points. Brake pads are going to vibrate and cause a squeal. That grease lets them vibrate smoothly rather than transmitting the noise to the caliper where it will get amplified.
Apr 24, 2024 at 12:54 PM
KATOTONIC
Very good to know. Certainly, something I hadn’t heard anywhere else before. I just recently had my brake lines and one of my calipers replaced when I ran into an issue with a seized caliper on my passenger side drive wheel. Terrified me because I thought immediately, I was having transmission issues and I know how expensive that work can be, and frankly my car isn’t worth sinking a ton of money into. Anyways, the shop mentioned how bad the degradation on my brake pads and rotors were, I can’t remember if I had ever taken a look at them in the ~6 years I’ve owned this car. But I’ve completed the first set of new rotors and pads, going to do the second set in the morning. I am curious though, when I placed in the back brake pad (or whichever one comes in direct contact with the caliper piston) the springy motion that I’ve seen other people achieve didn’t happen. I was able to put it in smoothly on the other side, but on that one side it seemed very stubborn and didn’t really move that well against its housing. I know some people use a small amount of grease in the channels, but I wasn’t sure if that was necessary.
Apr 24, 2024 at 1:47 PM
  • 110,248 POSTS
Remove the caliper, pads that seem tight, and the hardware from the mount. Take a file and clean all corrosion off the mount where the pad will ultimately be seated. Once that is clean, I always put a thin coat of brake lube on the steel mount before installing the hardware. It slows the rusting process which will ultimately press against the hardware causing the brake pad to stick.
I attached a pic below showing the locations I'm referring to. Make sure the areas I indicated are clean and free of rust and corrosion.
I hope this helps.
See pic below.
Apr 25, 2024 at 12:34 PM
