New battery installed but drains after four days
137,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
PRINCESS021
Install new battery but got a jump start after six days.
Mar 4, 2019 at 11:24 AM
  • 110,251 POSTS
Either you have a bad alternator or component within the charging system or an electrical draw. I am going to provide links that discuss how to test if the alternator is working as well as how to check for an electrical draw. I noted that you indicated little knowledge, so I will also include links showing how to check electrical components using basic tools. First, here is the testing equipment:
___________________
Here are the two tests I need you to follow. They are not too difficult and I'll be here to help if needed.
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know if this helps or if you have other questions. One last thought before you start. Make sure the battery terminals are clean and tight.
Mar 4, 2019 at 11:41 AM
