Shut off then check engine light turned on
2,600 MILES • MANUAL
KALEX
So my friends car completely shut off after start and the check engine light came on before it shut off. Will it be wise to give her a jump? It has a new battery.
Dec 5, 2020 at 10:35 PM
That should be fine but what I would do first if possible is scan for codes. Knowing what codes are there will let us know what the possible issues are. This may not be a drained battery but some other issue so a jump start may not make a difference. However, adding that jump to it, is not going to hurt anything.
Here is a guide that will help with this if needed:
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
Let us know what codes are there and we can go from there. Thanks
Dec 6, 2020 at 3:06 AM
