New battery causing new fault codes?
150,000 MILES • 3.0L • V6
JON F
I recently replaced the battery on my car listed above with a slightly larger one (720cca vs own 650cca) and several new codes appeared when I started it. The check eng light came on as well as the ABS and my new codes are P0750, p0743, p0760, p1451, p01747, p0135. Did I screw something up? I left an important piece of info; I crossed the jumper cables before I replaced the battery. I did start it with the old battery a couple of times after that and no codes appeared, but I'm not sure if crossing polarity damage can be a delayed process or not. All fuses are okay.
Sep 2, 2023 at 2:25 AM
  • 55,766 POSTS
It looks like you've provided a list of trouble codes for your 2001 Ford Taurus.
P0750 - Shift Solenoid 'A' Malfunction:
P0743 - Torque Converter Clutch Circuit Electrical:
P0760 - Shift Solenoid 'C' Malfunction:
P1451 - EVAP Control System Canister Vent Solenoid Circuit Malfunction:
P1747 - Electronic Pressure Control Solenoid 'A' Short Circuit:
P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1):
So, I would clear the codes and see if they come back. It could be a glitch due to connecting the battery. If they do come back please start a new thread for each code.
Sep 2, 2023 at 11:22 AM
JON F
Thank you very much Sir for taking the time to respond! Your explanation of these fault codes in layman's terms is more than I was expecting!
I retired recently after 47 years in the collision repair industry. Most of those years were spent building hard hits which usually require some sort of frame/suspension repair/replacement., but anything more than replacing a crushed pig-tail, splicing a cut wire, or checking for blown fuses, my electrical and diagnostic skills are very limited, to say the least.
I cleared the codes and unfortunately, they came back. As I stated in my original post, none of these codes appeared before my battery mishap.
So, I guess my question to you is, which code should I address first?
The car probably isn't worth the money I'm sinking into it. I recently replaced all 4 struts, tie rods, control arm bushings, brakes and rotors, plugs, wires, fuel pump, all the fluids, and 4 new tires. Oh, and that $150.00 battery. The thing has good compression, been we'll maintain since I bought it in 08 and all of all, it has been a very reliable ride up until now.
Once again, I want to thank you for your help!
Sep 2, 2023 at 11:50 PM
  • 55,766 POSTS
If all of these codes came up at once after the battery replacement, I would say the voltage surge took out the PCM, you can get a preprogrammed unit by searching Google or Ebay. Here is a guide to help walk you through the repair and I have included instructions in the images below for your car:
Sep 4, 2023 at 3:33 AM
JON F
Thank you! I will post my progress as it happens.
Sep 4, 2023 at 11:28 PM
  • 55,766 POSTS
You are welcome, please do!
Sep 5, 2023 at 4:23 AM
