Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Drivetrain
Transmission
Gear Position Sensor
Neutral safety switch wiring?
1996 FORD EXPLORER
180,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
WSTEINFELD6
MEMBER
1 POST
Wiring diagram 8 plug to 12 plug from 2000 Ford ranger
Jul 15, 2025 at 12:31 AM
Experienced Mechanic
Here is the pin outs for the plug for the neutral safety switch. Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Jul 15, 2025 at 11:18 AM
LEOPOLDOC
MEMBER
Can you give me a diagram for a 12 plug transmission range sensor for a Ford expedition 2000.? Thank you
Dec 28, 2025 at 4:34 AM
Sure, here you go, let me know if you need anything else.
Dec 29, 2025 at 1:40 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
